Industry Online Support
5/13/2010 5:28 PM | |
Posts: 3 Rating:
Thanks for the reply,if you look in the attached file you will see that we have 'DIAMON'in the early part of the program along with G18 but we still have the problem. We are running two spindles side by side the left side is ok the right side is nok even though the programs are identical.I can only imagine that this is maybe a parameter fault? Attachment1103F2311L.zip (76 Downloads) |
5/14/2010 3:49 PM | |
Posts: 3 Rating:
Thanks for your replies,this was the problem the machine is now running fine. |
5/14/2010 9:33 PM | |
Posts: 2 Rating:
You welcome. I'm glad that I can help. |
