10/25/2006 12:27 PM | |
Joined: 5/24/2006 Last visit: 11/14/2007 Posts: 93 Rating:
Hi schreyer, I propose using WinCC- user archive to do the job. I presonally has not try it before, but based on the manual, it's a customise Database which allows you to create your own field of data to be capture, e.g: Date, Time, ID nos, Description, IO tag. As for the putting the archived information back on your faceplate, i would suggest the following methods; [1] A trigger tag to WRITE to database, (e.g: Device name change -> entire information to be written into your database). By doing this, you will have unique ID nos in the database [2] On your faceplate, use the unique ID nos as the reference to put all your filed information via SQL + C script . (e.g: your HMI-IO text will be dynamic which with respect to the ID number you are reading from the Database) Hope that I didn't confuse you instead![:blush:] [:o] Anyone who has hand-on experience on this area? Correct me if I am WRONG! Kee |
10/25/2006 12:32 PM | |
Posts: 3149 Rating:
Hi, could perhaps the Option WinCC User Archives https://www.automation.siemens.com/hmi/html_76/products/software/wincc_optionen/userarchives.htm solve your problem?? In PCS7 I´d try to use AssetManagement http://pcs.khe.siemens.com/index.asp?Nr=1075&spezial=search nemo |
10/26/2006 10:08 AM | |
Posts: 3149 Rating:
Hi, unfortunately I´ve no special scripts available... http://support.automation.siemens.com/WW/view/en/19606614 http://support.automation.siemens.com/WW/view/en/15363614 And of course you can find some scripts in your WinCC online help > options > UserArchive nemo |
10/30/2006 10:48 AM | |
Joined: 9/27/2005 Last visit: 11/27/2007 Posts: 1398 Rating:
If you use User Archives to store the record you do not need to learn SQL. There are lots ofexamples of scripting access to a User Archive here. Have a try and just post here if you have any follow up questions. Salma |
11/7/2006 6:26 AM | |
Posts: 65 Rating:
Dear Salma, Hey thanks a million bro. Its much clearer now. Regards Schreyer |
11/7/2006 10:24 AM | |
Glad to help [:D] |
