2/18/2016 9:07 AM | |
hi RetroK, YES you also can see this by looking inside the top cover. regards, |
FCK WAR! |
2/18/2016 9:39 AM | |
Joined: 5/1/2013 Last visit: 8/21/2023 Posts: 425 Rating:
Can I connect only oneside? |
2/18/2016 9:11 PM | |
Joined: 1/21/2013 Last visit: 6/21/2023 Posts: 4617 Rating:
Hello RetroK, Sorry your code is for Digital output and your drawing is for Analog output !!!!! What connection you want for Digital or Analog??? For Digital output go to 218 For Analog output go to 464 https://support.industry.siemens.com/cs/attachments/8859629/s7300_module_data_manual_en-US_en-US.pdf
3/10/2016 5:39 AM | |
Posts: 63 Rating:
each side is for 4 chanel so if you want to use just less than 4 chanel you should connect only that side |
3/15/2016 10:02 AM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4794 Rating:
New question published by 9583815919 is split to a separate thread with the subject Connect s7 300 cpu and i/o module in one rack. Best regards |
