3/22/2006 10:04 AM | |
Posts: 3149 Rating:
Hi Peri, did you connect to Excel via OPC?? http://support.automation.siemens.com/WW/view/en/15049230 I guess, you´ve a problem with transfering your S7-DB to WinCC?? Did you proceed as mentioned in the faq? http://support.automation.siemens.com/WW/view/en/22062395 nemo |
3/22/2006 12:18 PM | |
Posts: 3149 Rating:
Hi Peri, don´t give up so fast, you could convert your string into an array of bytes: http://support.automation.siemens.com/WW/view/en/674578(example for SCL, check the SCL-source code http://support.automation.siemens.com/WW/view/en/1085941) UDT are unfortunetely not transferable.... nemo |
