3/6/2020 10:21 AM | |
Joined: 4/28/2015 Last visit: 1/25/2023 Posts: 385 Rating:
Hello, did you check settings of "Increments per revolution" and "fine resolution" at the technology object hardware interface...? Please have a look to the following manual:
3/6/2020 11:26 AM | |
Joined: 8/31/2005 Last visit: 1/23/2023 Posts: 2194 Rating:
This Information may help too: https://support.industry.siemens.com/cs/ww/en/view/109486133 |
3/9/2020 6:48 PM | |
Joined: 9/17/2015 Last visit: 1/20/2023 Posts: 137 Rating:
Hi, Thank you for sharing the manuals. I tried a lot of things from the manual but still could not get the right value. Half Circle of encoder = 360 degrees. I am attaching the code I hope it might give you more ideas of what I am doing wrong. The code is in TIA V15.1 updt4. Encoder steps = 8192 and revolution = 4096 AttachmentEncoder_testing TR_20200309_1340.zip (230 Downloads) |
3/14/2020 5:32 AM | |
Joined: 3/16/2015 Last visit: 10/10/2021 Posts: 1250 Rating:
Can you link to the manual of your encoder please. |
3/16/2020 8:02 PM | |
You can find the manual here. file:///C:/General%20Documents/Data%20Sheet%20&%20Manual/Siemens/TR-ECE-BA-DGB-0088-17.pdf AttachmentTR-ECE-BA-DGB-0088-17.pdf (176 Downloads) |
Last edited by: Jen_Moderator at: 03/17/2020 11:09:50Added manual as an attachment. |
