12/23/2010 11:32 AM | |
Posts: 8946 Rating: (999) |
Yes. |
5/4/2012 3:15 PM | |
Joined: 3/21/2006 Last visit: 9/10/2024 Posts: 10228 Rating: (1181) |
Hello, You can prepare extension cable by yourself usinghttp://support.automation.siemens.com/WW/view/en/19979721 No, you can't to connect this type 6FX2001-5FS12 with profibus. You need 6FX2001-5FP12. In this case is not need SM338. Need aGSD filein order to configure it in Step7. Best regards,Hristo Mihalev
8/2/2013 6:57 AM | |
Finally I found it. http://support.automation.siemens.com/WW/view/en/12663106 Best regards, Hristo Mihalev
8/29/2013 10:27 AM | |
Joined: 4/14/2010 Last visit: 8/6/2024 Posts: 525 Rating: (11) |
Dear, Can i replace attched Baumer encoder with 6FX2001-4FB00..?? Is the 6FX2001-4FB00 compatible with 6SL3055-0AA00-5CA2..?? we are searching for Siemens hollow shaft encoder are these available..?? Thanks. AttachmentEncoder_Baumer_HOG71.pdf (176 Downloads) |
MS |
9/4/2013 6:52 AM | |
Dear UMENCHO, are the 6FX2001-4FB00 and 6SL3055-0AA00-5CA2 supported for high speed frequency counting...??? Thanks. |
MS |
6/24/2016 1:07 PM | |
Posts: 4 Rating: (0) |
i CANNOT OPEN THIS FILE. CAN YOU HELP |
