3/14/2022 7:21 AM | |
Joined: 2/10/2022 Last visit: 4/16/2022 Posts: 2 Rating:
Dear Sir, I have issue of absolute position changing while repowering the servo drive with following hardware. PLC : S7_1517F-3 PN/DP Drive : 6SL3210-5FE11-0UF0 Motor : 1FL6044-1AF61-2LB1 I used technology object with TO Positioning Axis configuration, technology blocks and Telegram 3. MC Home with mode 7, after homed the axis while turning off the power then turning ON the Servo drive power Axis losing its actual position randomly. I tried Cyclic Absolute type in TO configuration but the program not downloading to the CPU, I have attached that Error snapshot. For your reference please find the attached snapshots of TO configuration parameters and Servo Drive backup fyl. Md muntazir Alam
Attachmentattachement.zip (130 Downloads) |
3/14/2022 2:51 PM | |
Joined: 11/4/2011 Last visit: 12/19/2022 Posts: 157 Rating:
Hey there! Most importantly ensure that you check the preconditions for enabling the technology object with MC_Power, as described in the other FAQ that is linked there. Regards, |
