6/28/2013 7:32 AM | |
Joined: 10/3/2010 Last visit: 12/11/2023 Posts: 1552 Rating:
What's the idea behind your question? Can you explain more in detail? In Graphic Designer, you have several ways by default to acces bits of an internal tag but i'm sure that's not what you really want, isn't it? Global Script as said above is an option but do you need constant monitoring of the bits? .. Tweety seems the most logic way to me. Brgds. PS: Please let us know if your issue is solved or not. |
