9/3/2023 10:56 AM | |
Joined: 12/28/2016 Last visit: 2/26/2025 Posts: 435 Rating:
Hello all I get the following error when I try to connect a client in TIA16
AttachmentAccess onto the project not possible. Error (0) The operation completed successfully.png (360 Downloads) |
https://pnap.ir |
9/4/2023 7:26 AM | |
Joined: 5/30/2022 Last visit: 4/25/2025 Posts: 634 Rating:
Hi Madadi, To see what might be happening and why this failure has occurred we would appreciate it if you could share the following information with us:
"What are the requirements for the use of SIMATIC WinCC in a Windows network?"
If this information really helps, you could use the Rate function. |
9/4/2023 9:39 AM | |
Hi Madadi, 1- Have you checked that everything is correct in the FAQ that I sent you? 2- As I see in the attached compatibility Excel (check the WinCC Professional box) you must have Update 5 installed, I am attaching a download link: Updates for WinCC Runtime Professional V16 AttachmentMicrosoft-Windows-10_es_2023-08-11 (2).xlsx (386 Downloads) |
Last edited by: Hazard_7 at: 09/04/2023 09:39:21If this information really helps, you could use the Rate function. |
