2/12/2025 12:54 PM | |
Hello federico_barrezueta Check out this entry in the help sysem: https://support.industry.siemens.com/cs/ww/en/view/109813306/109377913227 There is a restriction using dynamic tagnames of userdefined datatypes in Scripts: Check out the note in the link: "Current system behavior for dynamic access to elements of a user data type"Bye Murof |
