10/2/2013 12:29 PM | |||
Joined: 9/27/2006 Last visit: 3/21/2025 Posts: 12344 Rating:
Hello PTRZ; Your question is very vague, for example process data areas are generally defined by the programmer in a S7 CPU, in the form of DBs. I strongly suggest you take time to read up on the subject, and come back to the forum with more precise enquiries: For technical specs and links, follow this Product Support link:
If you program with Step 7: SIMATIC Working with STEP 7 V5.5 SIMATIC Programming with STEP 7 V5.5 SIMATIC Configuring Hardware and Communication Connections STEP 7 V5.5 If you program with TIA Portal: SIMATIC STEP 7 Engineering with STEP 7 V5.x or with STEP 7 as of V11 (TIA Portal) STEP 7 Basic V11.0 SP2 Hope this helps, Daniel Chartier |
2 thankful Users |
