5/28/2019 8:23 AM | |
Joined: 7/9/2015 Last visit: 3/21/2025 Posts: 4204 Rating:
Hello, have you ever tried to ping the CPU? Possibly. are blocked by router ports - check if port 102 is enabled. Which ports are used by the various services for data transfer via TCP and UDP and what should you watch out for when using routers and firewalls?
5/28/2019 10:58 AM | |
Joined: 9/21/2012 Last visit: 3/23/2025 Posts: 4344 Rating:
Is your subnet mask configured how? How wide the accessable IP area is? With subnet mask you can define that. |
