11/14/2017 9:48 AM | |
Joined: 8/1/2016 Last visit: 1/10/2025 Posts: 159 Rating:
Thanks Murof, I taught as much that i might need to make use of TON timer. But one question more, in a situation whereby i need to run 20 different machines in automatic, if i am to use TON timer, then i will be using 20 different timers. That's quite a lot of timers just to set delay time for the machine to run in auto mode and i can't use one timer for two machines..(i think) Please, any other idea on how to reduce the number of TON timers and at the same time i will achieve my automation task??? .Thanks in advanvce. Regards, Success. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 11/15/2017 9:30:41 AMNew subject after splitting |
