11/21/2024 4:12 PM | |
Joined: 2/26/2024 Last visit: 2/10/2025 Posts: 121 Rating:
I did not quite follow what you said, how to comment? |
12/11/2024 7:11 AM | |
Joined: 11/13/2018 Last visit: 1/30/2025 Posts: 80 Rating:
Hello Mr_Prof, You can query AlarmResults on the ‘Command fired’ event of the alarm control with this code:
Then you can loop through all AlarmResults to see which alarms were acknowledged and you can write those alarms and the username to somewhere (e.g. a CSV file). Example of such a loop:
Everything about the AlarmResult object is described in the manual. Hopefully this can get you started. |
Like it? Rate it! |
12/13/2024 1:21 PM | |
Hi Murof, Please see attached. At present, these are the only system tags available. |
12/16/2024 7:57 AM | |
Hello Mr_Prof, You can use @UserName. |
Like it? Rate it! |
12/16/2024 1:27 PM | |
When that tag is used the value that is returned is 0 - no username is displayed |
