2/27/2008 10:49 AM | |
Posts: 198 Rating: (17) |
i think that you have c scripting tool there open wincc > global scripts > there create a global action, put a tag to trigger (for example a bit) if you have split screen manager inside use ssmchangeworkfield function or one of ssm functions SSMChangeWorkField( '1',''@screen.pdl", TRUE ); if not use openpicture() else if :) you use some picture windowses you need to change picturename attribute of that .. |
2/29/2008 11:01 AM | |
Joined: 9/1/2005 Last visit: 12/2/2024 Posts: 4114 Rating: (195) |
Hello Kumulus, thank you for posting your solution! Hope too that it will be helpful for others with a similar problem. Best regards CS Moderator |
