4/29/2016 8:40 PM | |
Posts: 1 Rating:
Hello, I need the link to download the driver. But, these links are with problem. Can you help me? Because, i installed the driver and the cable and see the problem. ------------------------------------------------------------------------------------------ |
Last edited by: Blue Moderator at: 5/1/2016 8:20:13 PMNew subject after splitting |
4/29/2016 8:57 PM | |
Joined: 5/28/2008 Last visit: 3/12/2025 Posts: 4518 Rating:
Hello, Here's the link for all versions. You can find the version of your PC Adapter printed on it. |
Ayman Elotaify |
4/29/2016 9:46 PM | |
Joined: 3/28/2015 Last visit: 2/15/2025 Posts: 722 Rating:
Hello, S7 software include the update of Simatic drivers "PC Adapter USB A2 up to V8" So....you can't able to install these older versions in this case. If you remove V8 ,you can install these older versions. |
Eng.Mohamed Ibrahim |
4/29/2016 10:03 PM | |
Hello, A small correction, the driver is needed for Step 7 up to V5.4 Installation of the PC Adapter USB/USB Prommer Driver with STEP7 V5.5 Hope this helps. |
Ayman Elotaify |
8/29/2016 8:45 AM | |
Posts: 2 Rating:
Hi, How you solved it ?? I have the same problem... Tanks. |
2/3/2020 9:43 AM | |
Joined: 8/26/2017 Last visit: 7/6/2023 Posts: 3 Rating:
I have same problem with pc adapter usb a2 and windows 10 64 bits |
