7/17/2018 12:38 PM | |
Posts: 14 Rating:
Hello, i have tia 14, i have cpu 1215 and i add to it 1231 6ES7231-4HF32-0XB0 but the diag led always flashes any help please? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 7/17/2018 3:05:11 PMNew subject after splitting |
7/17/2018 4:27 PM | |
Joined: 7/7/2010 Last visit: 7/5/2022 Posts: 12406 Rating:
Have you followed Siemens recommendations for your analog signals and jumper unused voltage inputs and disable diagnostics on unused current inputs (among other suggestions from Siemens)? When you go online and check the diagnostics for the module, what does it tell you about all the channels? What about the PLC? Have you wired up the L+/M and ground to the module? Have you downloaded the hardware configuration (not the toolbar download button)?
science guy |
7/18/2018 10:35 AM | |
Posts: 14 Rating:
it said ''divergence in the subordinate component'' |
7/18/2018 10:41 AM | |
Posts: 14 Rating:
i didn' download the hardware configuration. where can i foud it and what is tha specific hardware that i need? it said not accessible. best regards . |
7/18/2018 11:13 AM | |
Posts: 14 Rating:
Hello wizerd, you mean this one? i tried it, nothing changes. |
