12/9/2011 2:39 PM | |
Joined: 9/27/2006 Last visit: 10/14/2024 Posts: 12287 Rating: (2685) |
Hello sree; I hope the answer I gave to another user in this thread can help you out: /tf/WW/en/Posts/60901 Hope this helps, Daniel Chartier |
12/10/2011 3:55 PM | |
Hello Sree; The procedure described in my earlier post is only for Profibus-DP, You will find the information required for the CP 5431 FMS in this document: SINEC CP 5431 FMS with COM 5431 FMS At this moment, I do not know if COM 5431 FMS is still available from Siemens, it is a discontinued package. You could possibly request a copy of the diskettes from some of the members here. Actually Profibus-FMS has been mostly abandonned in industrial environments, Industrial Ethernet has proven easier to install and more efficient than FMS. Is there any specific reason that you need to implement it at this time? If you wish to continue, you should find otherimportant help through this link: Where can you find sample programs and documentation for using the PROFIBUS FMS protocol for data communication between SIMATIC S5 modules and SIMATIC S7 modules as well as for data communication between SIMATIC S5 modules and PCs? Hope this helps, Daniel Chartier |
