12/10/2018 10:51 AM | ||
Joined: 10/11/2006 Last visit: 1/27/2023 Posts: 5404 Rating:
Hello, because Simotion technology object. You have to check the configuration mask of the TO. 3.1.2 Axis-drive relationship https://support.industry.siemens.com/cs/ww/en/view/109757317 When the valve is connected to a TO, it is only possible to do a small program to enable the axis and give a setpoint. There is an application "Axisfunctionblock". with this block it is possible control axis very simple. https://support.industry.siemens.com/cs/ww/en/view/48816191 Component replacement depends on the settings in your project. topology comparison setting, safety, ... For S120: 14.9 Component replacement https://support.industry.siemens.com/cs/ww/en/view/109757573 For G120: Chapter 9.2 https://support.industry.siemens.com/cs/ww/en/view/109757230 With Simotion, you have to put the CF-Card in the new device. Chapter 5.3.4 https://support.industry.siemens.com/cs/ww/en/view/109757329 |
With best regards, |
1/2/2019 9:48 AM | |
Hello, it is described in chapter 14.9 Component replacement https://support.industry.siemens.com/cs/ww/en/view/109757573 |
1/3/2019 6:22 AM | |
Joined: 5/12/2006 Last visit: 1/27/2023 Posts: 21197 Rating:
Hello, capter 9 https://support.industry.siemens.com/cs/ww/en/view/109760403 Regards Christoph |
