12/9/2024 10:15 AM | |
Joined: 4/27/2023 Last visit: 3/9/2025 Posts: 7 Rating:
same problem ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 12/12/2024 09:19:32New subject after splitting "Be you, everything else is already taken" |
12/10/2024 6:12 AM | |
Joined: 1/21/2013 Last visit: 4/25/2025 Posts: 3775 Rating:
Hi, The new version V1.1.0.0 of the HMI Panel Image Updater has been released for download yesterday afternoon. You must use this version to enable login. Kind regards |
12/10/2024 11:47 AM | |
Hi FlyingMario,
There are also reports of login problems for the HMI Panel Image Updater in the German section of the forum. However, it works for me, and to verify, I also tested successfully with a newly created account. Please check your access rights. Are you allowed to download export restricted software? Kind regards |
Last edited by: Stefan Arcularius at: 12/10/2024 12:36:31Add paragraph regarding access rights |
12/11/2024 6:26 AM | |
Hello everyone, Please make sure you only have the new V1.1.0.0 version of the HMI Panel Image Updater (PIU) installed. A previously installed version V1.0.0.0 will remain installed during the installation and may cause problems. So please remove V1.0.0.0 before installing V1.1.0.0. Hope this helps. Kind regards |
