2/7/2019 8:04 PM | |
Joined: 1/1/2019 Last visit: 10/29/2022 Posts: 2 Rating:
hello i have the same project like you , for label cutting small macchine i make all right the parameter axis , but after some rotation / revolution ,the step motor advance 1mm this do wrong cutting . plase can you help me to solve thanks in advance ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 2/8/2019 6:28:02 AMNew subject after splitting |
2/8/2019 9:48 AM | |
Joined: 4/28/2015 Last visit: 1/25/2023 Posts: 385 Rating:
Hello, did you check to use a technology object "PositioningAxis" of S7-1200 with PTO...? Is this not possible for you. It would be easier to configure mechanic behavior... For more information, see manual chapter 5 and following (specially chapter 5.4.3.2): SIMATIC STEP 7 S7-1200 Motion Control V6.0 in TIA Portal V15 (12/2017) |
