8/8/2017 9:17 AM | |
hi Eli_47, this term is not really correct. The RECV-block receives data from the Ethernet CP. I found something that may help you, with your problem in this FAQ: How do you program the communication blocks FC50 and FC60?
So when you have an area of 100Bytes specified on the RCV and you are only sending 50 Byte, your NDR flag will be only set every second time. hope this helps, regards, |
8/8/2017 12:11 PM | |
Joined: 8/23/2012 Last visit: 2/19/2025 Posts: 118 Rating:
But when i comment calling of function AG_SEND inside S7-300 - i continue see good state of connection inside S7-400. When i use AG_CTNL funtction with job 2 (reset connection) and reistablish connection to S7-300 i see new values (but only once). Very strange... Regards, Eli |
8/8/2017 5:42 PM | |
Posts: 3093 Rating:
Hello Eli_47, Regards, |
8/9/2017 8:31 PM | |
And problem is solved. |
8/10/2017 9:17 AM | |
solved by what? are you using ISO on TCP now? |
FCK WAR! |
