3/18/2015 6:58 PM | |
Posts: 93 Rating:
Hi expert, i m beginer of plc programming.we are data transfer between two s7-400 cpu.In my program backup programmer lock the fc50. i not able to open it.DB200 is used for both plc.now 80bytes is available in DB200 all bytes cousumed it. i need to extend the byte level in db200 so i did program in above 80 bytes in both plc.but data not transfer both cpu.i refer help menu for fc 50 mentiond send := p#db99.dbx10.0 byte 240. now fc50 is locked condition so how to extend the byte level.other wise i need to do again create call fc50 fucntion any method is there pls guide me here i attached all the picture document. Regards, suryamuni. AttachmentDATA EXCHANGE.pptx (116 Downloads) |
3/19/2015 5:29 PM | |
Posts: 93 Rating:
Hi expert, here i attached the picture for better understanding of my problem.I calling fc 50(AG SEND/AG REC) in another s7-400 plc that fc50 automatically locked condition,now i understand fc50 not locked by programmer i am wrongly say lost post. Then i searched OB-1, FC-180 and FDB816 there is no call in fc50 AG SENT.where is control the the db200 accessing address in program. This attached file i increase the byte in both plc DB-200 temporary trigger some bit in FC-180 and FDB816 go to on line monitor mode there is no data transfer between two plc .pls guide me to solve the issue. Regards, suryamuni. AttachmentDATA NOT TRANSFER.pptx (119 Downloads) |
3/26/2015 6:15 AM | |
Posts: 93 Rating:
Hi expert, Any one give the guid for me to be solve the issue |
4/6/2015 5:34 AM | |
Posts: 93 Rating:
Hi expert, Pls anybody reply me. Regards, Suryamuni. |
4/14/2015 3:12 PM | |
Posts: 93 Rating:
Hi saravana kumar, My backup data is much more space around 1gb,so i cant able to sent whole project. Thanks & Regards, Suryamuni. |
4/14/2015 3:26 PM | |
Posts: 93 Rating:
Hi expert, I can go through all possible way of data exchange my program.Now i got it our program global data communication used for exchange the data between two CPU.Thanks for all your support and reply. Now i have one more problem related editing the global data program. Here i attached that photo realated my qusetions. 1.Now i can increase the byte above 80 bute,this global data communication maximum how much byte is possible to data transfer? 2.During my data editing time i select send/receive it's ok. But GD ID is how to edit? i select the GD ID row it show shaded in GD ID box. Guide me how to edit the GD ID? i m wating for your reply. Advance thanks & Regards, Suryamuni. Attachmentincrease byte length.pptx (98 Downloads) |
4/24/2015 9:54 AM | |
Posts: 93 Rating:
Hi expert, Anyone help me how to create (or) edit the GD ID. i m waiting for reply. Thanks&Regards, Suryamuni |
