10/10/2019 3:24 PM | |
Joined: 9/27/2006 Last visit: 6/4/2023 Posts: 12033 Rating:
Hello PCS 7; You can easily find such information using the Search box at the right of thios page, with the part number as a search term. For your AI module, the information is shown as an attach,ment below. A successor module designation means that the new module will be a 1-on-1 replacement for the old one (maybe some electronic parts are no longer available to build the old module, and have been replaced in the new one, without changing functionalities). So you can replace the old part number on the rack with a new module without changes in the hardware configuration. As far as the AO module, ithe part number is still active and does not require replacement. https://support.industry.siemens.com/cs/pd/521725?pdti=pi&dl=en&lc=en-WW Hope this helps, Daniel Chartier |
