5/23/2021 9:16 PM | |
Joined: 2/6/2020 Last visit: 2/17/2023 Posts: 2 Rating: (0) |
hi. I am using AI8 channel module 6ES7134-6JF00-0CA1 with A0 base unit. It is measuring the temperature incorrectly with a K-type thermocouple. Should I use the A1-type base ? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 05/25/2021 12:24:57New subject after splitting |
5/25/2021 9:45 PM | |
Joined: 8/12/2020 Last visit: 7/15/2024 Posts: 41 Rating: (3) |
Hi ahmet.34, You can find the find the base units compatible with the different input modules in the following link: Which Base Units can you use for the IO modules of the ET 200SP? Br, |
