10/31/2013 12:50 PM | |
Posts: 3609 Rating: (29) |
Import of a Technical Question of the User premraj
10/31/2013 1:18 PM | |
Joined: 4/19/2008 Last visit: 9/3/2024 Posts: 1525 Rating: (159) |
Hello premraj, Download the SIMATIC S7-300 S7-300 Module data Manual & See the Chapter No. 5 Principles of analog modules, You will get the All the Detail |
Ammy |
10/31/2013 8:47 PM | |
Joined: 9/27/2006 Last visit: 9/7/2024 Posts: 12282 Rating: (2682)
Hello premraj; The number of bits qualifying an analog module refers toits "resolution", or size of numeric steps for each vriation of input or output value. Ammy,s referal is quite good, you should follow his lead for a detailed technical reference.. You could also look into this earlier discussion on the same subject from the forum: Analog module - Siemens Industry Online Support |
