4/30/2020 11:37 PM | |
Posts: 3 Rating:
Hi, I too have the issue with alarm buffer. In TIA portal , i created a new user defined alarm tag for hmi. Assigning the tag as buffer, showing proper alarm message. The PLC is running 24/7. The issue is the alarm buffer is not showing the proper date and time. Every day it changes the date and time of the current date, without the condition being not satisfied. I have checked the wires and they were perfect. I believe there is no lose connection. Someone please help me to sort this out ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 05/04/2020 08:34:48New subject after splitting |
5/1/2020 8:45 AM | |
Joined: 2/5/2013 Last visit: 4/23/2025 Posts: 325 Rating:
Hi rahul, First you need to check whether HMI is showing correct Date and Time. As Alarms and Historical Data gets logged as per HMI time. If HMI is not showing correct Date and Time then you first need to update HMI time as per current Date and Time then this link may be help you. Br, AmolG. |
Please rate it. |
