7/25/2007 1:00 PM | |
Posts: 3149 Rating:
Hi perhaps this FAQ can give some information? http://support.automation.siemens.com/WW/view/en/24706826 Normally it´s important for me from which area of my plant the alarms are coming, but that´s quite easy, if you are using the Technical Hierarchy in "PCS7/ES > view > plant view" and place your alarmblocks there acc. to your plant-structure. nemo |
7/26/2007 8:52 AM | |
Posts: 3149 Rating:
Hi at the moment it´s not clear to me, why you want to know this, because the system is setting the bit for acknoledgement,...automaticly and handing over this values to your S7...? http://support.automation.siemens.com/WW/view/en/17778440 nemo |
