9/16/2006 6:14 AM | |
Posts: 3 Rating:
So, as for you, there is no way to find and display the messages came long ago if my database is too big ? |
10/18/2006 10:00 AM | |
Joined: 9/27/2005 Last visit: 11/27/2007 Posts: 1398 Rating:
The problem you describe is not normal behaviour. Alarms should be stored and displayed depending on the configuration set in the Alarm Logging Editor. It is likely the fault is because of a configuration setting or a resource issue. |
