4/28/2015 6:28 AM | |
Joined: 10/21/2013 Last visit: 9/19/2024 Posts: 417 Rating: (28) |
Hi matthew , you can filter the outgoing alarm from alarm buffer by using filter option in the alarm buffer properties.. for eg: you configure all your motor alarm as motor:run motor :fault motor:temp high in your HMI alarm text field.. and in hmi alarm filter property give motor: it displays oly motor alarm Attachmentalarm.zip (303 Downloads) |
4/3/2018 11:42 AM | |
Joined: 6/19/2017 Last visit: 9/6/2024 Posts: 8175 Rating: (173) |
New question published by Seragdin is split to a separate thread with the subject Need to make invisible status alarm in journal and change message . Best regards |
