11/21/2006 8:14 AM | |
Posts: 3149 Rating:
Hi, which WinCC / microsoft version are you using? Could you please post your WinCC diagnose files in the forum? nemo |
11/21/2006 10:24 AM | |
Posts: 66 Rating:
Hia and Thanks for the reply Nemo. Simatic WinCC K6.0.3.0, hotfix 2 (01010017) Where do I find the diagnose files? |
11/21/2006 12:23 PM | |
Posts: 3149 Rating:
Hi, you will find the diagnose files in the folder ...\wincc\diagnose Are you using a lot of scripts? Then the APDIAG-tool can give usefull hints for programming errors http://support.automation.siemens.com/WW/view/en/22196555 nemo |
11/22/2006 1:11 PM | |
Posts: 66 Rating:
Hia! Really appreciate your help Nemo! I'm using internal tags for the status tags. Included are zip file from c:\programfiles\Siemens\WinCC\Diagnose Is this the files you need? Please let me know if you need anything else! Thanks V AttachmentWinCC_Op_01.zip (124 Downloads) |
11/22/2006 2:40 PM | |
Posts: 3149 Rating:
Hi, your diagnosefiles just show some minor entries ...where/how do you set this status-tag? By scripting or by tags from your S7-CPU? nemo |
