3/1/2024 10:41 AM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15350 Rating:
Hello AutoGen_7588176 Does it work if you use a local path for logging? I would always do the logging on a local storage. You can use this to make copies of the current logs and copy it to the netshare. Then if the network has an error the logging will run without an impact on this. https://support.industry.siemens.com/cs/ww/en/view/63042926 Bye Murof |
