8/30/2023 3:07 PM | |
Joined: 7/19/2010 Last visit: 2/28/2025 Posts: 53 Rating:
Higoudarzi91, Try this manual since page 13869: Link:STEP_7_WinCC_V18_enUS_en-US.pdf - SIMATIC STEP 7 Basic/Professional V18 and SIMAT... - ID: 109815056 - Industry Support Siemens |
Esdras Lopes Cardoso |
9/4/2023 7:13 AM | |
Hello goudarzi91 descrete alarms uses the timestampl out of the HMI and It could be that the timestamp is not 100% exact because the triggertags have also cycles for communication. If you need exactl timestamps from PLC then you can use PLC Alarms -> Program_alarm Here you will find some information about Program_alarm too: https://support.industry.siemens.com/cs/ww/en/view/62121503 Bye Murof |
9/11/2023 5:31 AM | |
Joined: 5/11/2022 Last visit: 4/20/2025 Posts: 71 Rating:
Thanks a bunch |
