9/19/2006 6:54 AM | |
Posts: 5 Rating: (0) |
I have installed “STEP 7 v5.3 sp3” for several months, and it works well. But today, when I open STEP 7, an error dialog box appears, and I also cannot open the Automation License Manager. Because the Automation LicenseManager Service cannot be started. I tried the SIEMENS FAQ: http://support.automation.siemens.com/WW/view/en/18865336 But in the “Event Viewer”, I found my computer’s error information cannot match the FAQ’s error information. It seems that the “Automation License Key Service” firstly successfully started but encountered error at the same time.
AttachmentLicense Problem.zip (671 Downloads) |
9/19/2006 2:03 PM | |
Hi, Dec, I have followed the SIEMENS FAQ even if the error code doesnot match. So I decided to update my MDAC. But after I download the MDAC from the address which the SIEMENS FAQ offered: I cannot install it! The error dialog box showed that the MDAC isnot available for this OS. I tried a lot of MDAC versions, but none of them can be installed. It made me crazy! |
9/19/2006 2:27 PM | |
Joined: 9/28/2005 Last visit: 12/14/2022 Posts: 414 Rating: (28) |
Hi, The link you gave sends you to MDAC 2.8. Try this link to go to the download page of MDAC 2.8+SP1 |
Smurf |
9/19/2006 4:44 PM | |
Hi, Smurf, My OS is English version, not Deutsch version. But the link goes to the Deutsch version of MDAC. Does it matter? |
9/19/2006 4:54 PM | |
Joined: 4/24/2006 Last visit: 9/20/2024 Posts: 8742 Rating: (1168) |
Hello SuperKevin, If your Windows language is English, you should go to following link: http://www.microsoft.com/downloads/details.aspx?familyid=78CAC895-EFC2-4F8E-A9E0-3A1AFBD5922E&displaylang=en Best regards, Wizard |
