5/1/2023 8:02 AM | |
Joined: 1/6/2018 Last visit: 9/16/2023 Posts: 52 Rating:
Greetings. I've made this contraption, in order to use a cursor key to cycle some pages and use the cursor keys to illuminate screen for 15 seconds each time a key is pressed. In theory it works. But not on the actual machine. Amber lights up only for the first 15 seconds, and the page feature only shows the first page. Advice, please? AttachmentCircuit Diagram1.zip (208 Downloads) |
5/1/2023 1:44 PM | |
Let me populate it further. And the more I use it the more issues I see. What I do not understand is why it also shows failure text b075 (at present high) but it refuses to show b096. because of priority? No you need to go to the clock and press esc to access the menu. Since I am on the b057 at the start it shouldn't matter. Ok lets suppose that you solved, Up. You still have to explain Down, Right and Left Also, You see what I added in the bottom? Program supposes that I4 must be off for b058 to be able to produce high to energise relay. This empiricaly, isn't the case. I needed to set I4 high (provided 24vdc from logo transformer) In order for the relay to energise. Like what the #?! Do you need more data? Can someone tell me what to do? AttachmentCircuit Diagram1.zip (126 Downloads) |
5/1/2023 2:23 PM | |
How can I send you video from my phone? |
5/1/2023 2:37 PM | |
Joined: 12/18/2014 Last visit: 12/9/2023 Posts: 31592 Rating:
Here's an example for the shift register.
AttachmentShift_register_8.1 & 8.2.zip (134 Downloads) |
5/1/2023 2:45 PM | |
https://streamable.com/592wtu I do not understand. Then how it displays the first page? Why does it work in simulation? In the video, what I manipulate is I4.... Also I do a reset. I also want the data logger to log Average Value, but all I got is 0. Doesn't matter if I data log a mathematic instruction, out of it, it still is 0. Attachment3_18.zip (121 Downloads) |
