10/26/2021 8:27 PM | |
Joined: 5/20/2019 Last visit: 12/20/2021 Posts: 14 Rating:
Hello everyone . I need to create an interface between an s5 (6ES5103-8MA03) and a HMI last generation (comfort panel). Is there any software or hardware that will allow me to communicate? Thank you.. ------------------------------------------------------------------------------------------ |
Last edited by: Jordanburgos at: 10/26/2021 20:28:51Last edited by: CS Moderator at: 10/26/2021 22:29:47New subject after splitting |
10/30/2021 11:12 AM | |
Joined: 12/1/2009 Last visit: 5/2/2023 Posts: 669 Rating:
Hi, You should forget about the comfort panels in this case because they don't support your S5 CPU. I advise you to chek out the panels from these two vendors below. Some of their HMI panles still do support your old S5 CPU. https://www.beijerelectronics.com/en/Products/software/ix-hmi-software/Driver___list or https://www.proface.com/en/product/soft/gpproex/driver_plc You need to check for these interfaces. SIMATIC S5 CPU Direct or SIMATIC - S5 PG/AS511 In case you insist to use a comfort panel you need to replace the S5 with a S7 CPU. Best Regards. |
Give us your feedback and show us your respect! |
2 thankful Users |
