5/29/2018 4:27 PM | |
Joined: 9/23/2005 Last visit: 4/24/2025 Posts: 5000 Rating:
Ad. 1 -> here |
Regards, |
5/29/2018 5:14 PM | |
Posts: 4 Rating:
That is indeed how it works in practice, it's just odd to me since you need 16 bits to represent that whole range. I'm probably just nitpicking here, and there is actually some other scaling going on before I see the Dword value, probably for interoperability between all the AI modules or something.
Last edited by: tbycz at: 5/29/2018 5:30:37 PMLast edited by: tbycz at: 5/29/2018 5:41:03 PMLast edited by: tbycz at: 5/29/2018 6:08:25 PM |
5/29/2018 9:04 PM | |
I'd say it's cleaver. You do not need to bother yourself what is actual AI/AO resolution. And this is achieved by simple left justifying.
Regards, |
5/30/2018 8:34 AM | |
Joined: 4/24/2006 Last visit: 4/25/2025 Posts: 8969 Rating:
Hello, Please have a look at attachment, for more information about resolution. Best regards, Wizard |
5/30/2018 8:44 AM | |
Hello, Here is some information about downloading HMI panel: How can you transfer a WinCC (TIA Portal) configuration to an operator panel using Ethernet? Try to use 'extended download' Best regards, Wizard |
5/30/2018 8:27 PM | |
Posts: 4 Rating:
I have done the extended download several times. Pings to the HMI and PLC are all good. I get the option to "Overwrite if objects exist online?" and I always choose "Overwrite All", but I have never seen the options "Do you want to overwrite existing user administration data of this HMI device?", or "Do you want to overwrite the existing recipe data on this HMI device?". The same warnings remain after extended download. There is no reason for these warnings to exist that I can see. Runtime and firmware are version 14.00.00.00_31.1
