8/27/2014 11:54 AM | |
Joined: 4/22/2010 Last visit: 5/3/2024 Posts: 5697 Rating: (715) |
Hello, first you need to Scale the signal after that you can use a totalizer. How can you add together physical flow measurements (mass flow rate, for example) to a total value in STEP 7 (TIA Portal)? Regards, Marcjan |
Problem solved? |
