5/31/2011 12:23 PM | |
Posts: 8946 Rating:
PLEASE: In the last days, there where 10 posts with same question. Search for "FC105, FC106". |
5/31/2011 12:26 PM | |
Joined: 3/21/2006 Last visit: 4/19/2022 Posts: 10221 Rating:
Why do I think saw the same issue this morning in other thread? And my answer was - How and for which analog measurements can you use the function FC105 "SCALE" to convert the integer values (INT) into real number values? and shar explained you some tips how to do the logic. Perhaps Working with STEP 7 V5.4 Getting Started might be useful... best regards, Hristo Mihalev The other one /tf/WW/en/Posts/58586#top Isn't necessary to put more then once the same issue here! Now Moderators should delete it. Just more job... |
5/31/2011 12:33 PM | |
Posts: 8946 Rating:
To fullfill: /tf/WW/en/Posts/55674 /tf/WW/en/Posts/47922 /tf/WW/en/Posts/47044 /tf/WW/en/Posts/38952 /tf/WW/en/Posts/33652 /tf/WW/en/Posts/36372 /tf/WW/en/Posts/2867 /tf/WW/en/Posts/58117 /tf/WW/en/Posts/54522 and there is much more here... Also check FAQ... |
5/31/2011 12:44 PM | |
Joined: 4/24/2009 Last visit: 11/1/2021 Posts: 2687 Rating:
Thread closed, because question is already published in the following thread I need real to real conversion, word to real conversion in s7-300 software. Best regards O_Moderator |
