1/28/2013 7:51 AM | |
Joined: 8/31/2010 Last visit: 2/3/2023 Posts: 1498 Rating:
Hello ramzi140, For which have a look at this FAQ - In STEP 7 (TIA Portal) V11, how can you scale integer values in real numbers and real values in integer numbers for analog measurements? |
Like it? Rate it! |
1/28/2013 10:39 AM | |
Posts: 11 Rating:
Hello ramzi140, For which have a look at this FAQ - In STEP 7 (TIA Portal) V11, how can you scale integer values in real numbers and real values in integer numbers for analog measurements? thank for the replay but do i have to scale the input from 4-20 mA to 0-20 mA then use this way ,or this wayis enough. regards
1/28/2013 10:46 AM | |
thank for the replay but do i have to scale the input from 4-20 mA to 0-20 mA then use this way ,or this wayis enough. regards Hello ramzi140, What do you mean by "but do i have to scale the input from 4-20 mA to 0-20 mA then use this way ,or this wayis enough."?? Can you explain it in other words. |
Like it? Rate it! |
