8/2/2009 12:10 PM | |
Joined: 10/7/2005 Last visit: 9/26/2023 Posts: 2988 Rating:
Hello RoyNeck it depends on the AI card that you use, have a look of chapter 6 of the S7 300 Module Datamanual to determine this for your card. I hope this helps |
Cheers |
8/2/2009 2:24 PM | |
Oops, I don't know why I assumed ET200M Anyway, it's a similar story, the main manual is: SIMATIC Distributed I/O System ET 200S Having said that, owing to the range of ET200S modules and somewhat moreregularrelease of newer modules for it, you won't find all available modules in this manual. Siemens does however release individual model spec's for these, soif your AI card in not the above mentioned one, do a part number search for it from the main service & support page(https://support.automation.siemens.com). Alternatively, Siemens has a dedicated manual collection webpage called: Technical Documentation - Simatic Portal Automation Systems You'll find it'll come in very handy when you are only looking for technical doc's. |
8/3/2009 6:48 AM | |
Posts: 2348 Rating:
Think best is just measure it:^) As i remember there are resistance 25/50 or 250/500 ohms. |
8/3/2009 8:31 AM | |
Joined: 7/13/2009 Last visit: 3/26/2023 Posts: 5 Rating:
This assumes one already has a module in one's possession |
8/3/2009 1:50 PM | |
Posts: 2348 Rating:
)) Tell your order number - we have some of them avaible |
