9/13/2015 3:47 PM | |
Joined: 3/30/2011 Last visit: 9/18/2024 Posts: 736 Rating: (256) |
Hello mbt2412, you have to check: 1- if parametrization in hw configuration is correct (according to your sensors). 2-if wiring is correct (see cap 6.7 for detail). 3-this board have some hardware measurement modules. Check modules are in correct position (see cap 6.7.2). If all check give positive results and and you still have bad values you have to check sensors. Maybe can help to change configuration and connect a resistor to se if you can read resistance value. If you cant read neither a resistor your board is defective. Best regards |
9/22/2015 6:31 PM | |
Posts: 45 Rating: (0) |
i have changed my measuring range from 2 wire to 4 wire current ... now the milliamps is coming . Tell me do i have to short the rest of the other terminal if and why? |
