12/8/2008 6:30 PM | |
Posts: 3 Rating: (0) |
Cheers Werewolf, I will remove all my inputs from the card and start with a known voltage. Soon be Christmas I might have it fixed by then. MaintMan |
12/8/2008 7:22 PM | |
Joined: 2/22/2008 Last visit: 2/2/2023 Posts: 39 Rating: (4) |
Have you tried a big hammer? |
12/9/2008 5:43 PM | |
Thank you MaxAutomationUKi tried that and it failed. Management wern't to happy, so i left it with day shift and the OEM and they fixed it, or overcame it depending on your point of view. A last gasp suggestion was to up the filtering from 10hz, (it has always been this and the OEM confirms that they setthis value to 10hz with no problems),to 400hz. Now all readings are correct. Maintman |
