9/29/2008 10:31 AM | |
Posts: 17 Rating: (0) |
Hi, Is getting the connectivity pack option the only way to solve this problem? Regards |
9/29/2008 10:37 AM | |
Hi, I don't find any manual of the connectivity pack. Do I have to buy the CP before I get some information about it? Regards Varzu |
9/29/2008 11:54 AM | |
Joined: 6/13/2006 Last visit: 2/11/2023 Posts: 341 Rating: (24) |
Yes , you would get all the informationwith license and software package. |
9/29/2008 1:02 PM | |
Joined: 4/5/2006 Last visit: 12/3/2024 Posts: 917 Rating: (63) |
tat's right, you have to store date/time in a custom archivewith start production event& end production event (your ID production + code start/stop production). But not sure you really need Connectivity pack. You can use other system likestore data in custom files (you have to manage historycal dat in this case) or use user archive (user archive is an optional WinCC tool that manage redundancy Server too). So..there are different way to do that depending what you want spendforoptional pakages or spend in effort todo yourself. But you need store data/time for each ID you want in a custom archive, then write a script for: - look for ID from user archive - read data/time start/end production - use date/time read from user archive to retrive for trend display Best Regards |
9/29/2008 2:49 PM | |
Hi CBo thanks for the confirmation. Varzu its good thatcan use Wincc database driver for your custome use without any optional package on the WinCC Station. Go to the site http://www.wincc.net/for good example of fetching data from WinCC MSSQL DB reagrds, rit03 |
Last edited by: rit03 at: 9/29/2008 2:51 PMLast edited by: rit03 at: 9/29/2008 2:50 PM |
9/30/2008 7:48 AM | |
Thanks for your help. I'll have to do some research and programming and perhaps I'll returnto this subject again. Regard Varzu |
