2/1/2012 2:08 PM | |
Posts: 510 Rating:
I have attached a document with screen captures that document the process I went through to achieve what you are trying to do. In Step 7 V5.4 SP4, you have to type in the "S7_m_c" and the "true"in the object properties for the items in the DB. I typed in the first one, copied the line and then pasted it in for the other 5. If you have a lot to do, I usually do one, generate the source file, edit the source file to copy and paste the rest in. When I am done I compile the source I hope this helps. billwest
AttachmentOCM.pdf (199 Downloads) |
