5/4/2011 1:44 AM | |
Joined: 9/27/2006 Last visit: 3/14/2025 Posts: 12344 Rating:
Hello MRG; Basically, you will always require a DP master on the bus; mostly, Profibus-DP uses a master-slave communication setup. However, certain slaves, known as I-slaves (Intelligent slaves, basically CPUs configured as DP slaves) can also use 'Direct Data Exchange" with other ordinary slaves on the bus to read and write from their memory areas, while still exchanging data with the DP master. See the following FAQ for more details: http://support.automation.siemens.com/WW/view/en/15196761 Hope this helps, Daniel Chartier |
5/6/2011 2:05 PM | |
Joined: 9/1/2005 Last visit: 3/10/2025 Posts: 4113 Rating:
Dear MRG, I'm sorry for the confusion Trying to do it better next time Best regards CS Moderator |
