6/7/2013 11:21 AM | |
Joined: 5/19/2011 Last visit: 1/20/2023 Posts: 196 Rating:
If you have HMI advance software you can download the ARC file with help of it. Please check attached documents for your reference. Before donloading the data clear NC & PLC.Make sure that you have complet backup with you. NC.ARC & PLC.ARC. AttachmentNCK-PLC General reset complete.pdf (781 Downloads) |
6/11/2013 12:24 PM | |
Please check attached file for loading & recomissioning the 810D. You also require to load motor data if your backup is not correctly loaded or wrong. Please go starup->motor/controller & enter all motor data for respective axis.then save boot file. Regards, nanu Attachment810 D Commissioning.pdf (609 Downloads) |
6/15/2013 10:12 AM | |
Posts: 11 Rating:
Hi, I eventually download NC.ARC file by WINPCIN and every things are going well. Thanks so much.
