4/25/2008 8:22 AM | |
Posts: 8 Rating:
Hello again! I have a problem to load data from archive. Load data from archive takes about 8 minutes, and i think thats too long time? There is couple of appendix with this post. This Archive have 10 tags to archive. I hope someone can help me! Thanks! Attachmentfiles.zip (18 Downloads) |
4/25/2008 9:56 AM | |
Posts: 125 Rating:
Hi, try to attempt the timerange directly in the Control (in Runtime -> Properties of WinCC xx Control -> Tab: Column). Then check, if the time still so long. Then you can check the archiveconfiguration. (Timerange of single segment and all segments) see: http://support.automation.siemens.com/WW/view/en/15399096 or: http://support.automation.siemens.com/WW/view/en/24113228 regards |
4/25/2008 12:39 PM | |
Posts: 8 Rating:
I tryed those but still it takes ~8minutes... I have also a lot of olderdata in other archive. (about 1Gb) |
