2/8/2018 7:50 AM | |
Joined: 4/28/2015 Last visit: 4/11/2025 Posts: 10846 Rating:
Den dobry, maybe idea, with C script? I don't know exactly... |
With best regards... |
2/8/2018 2:57 PM | |
Hello @ Duris_I: WinCC comfort/Advanced cannot use C Script, its not like WInCC Professional or WinCC v7.X --> InVB Script all datatypes are VARIANT but there is a theoretical way of casting with the functions: CInt or CBool and so on In your case you can try "CDbl". How to work with Arrays in Sripts you can see in this FAQ: https://support.industry.siemens.com/cs/ww/en/view/26165877 (Nr2. and Nr3 ; Its for flexible but almost everything is also working in TIA Portal) Hope this helps Bye Murof |
Last edited by: Murof at: 2/8/2018 2:58:01 PMIf this Information really helps, you could use the Rate function |
