10/9/2008 2:07 AM | |
Posts: 1064 Rating:
You can use 2 distributors part # 3rk1-901-1nn00 if you are using as-i flat cable but keep in mind that you have to stay under 100 meters in length if it's over 100 meters in length total for the whole bus then you will need to install a as-i repeater or extender see the following manual for more information http://support.automation.siemens.com/WW/view/en/26250840 |
